My 77B has high oil pressure. High being about 60psi at 1000rpm and 85 to 90psi at 3000rpm. I have checked the screen in the sump an it was fine. I replaced the relief valve and spring. I tried an engine flush. The thing that really bothers me is when i take the oil filler cap off I do not get any blow by or see any oil flowing. The older cars that I have owned when you take off the oil filler cap oil will blow out it. I have started and ran it several times for 10 to 20 minutes and it has not blown up yet. Does anyone have any suggestions?
Jun 2, 2009 at 9:25 AM
