I will be better able to help you if I can hear it.
Jan 7, 2019 at 10:52 PM
ARTHUR STITILIS
MEMBER
The car is a sister. I have to ride on it to make a movie. Sound like that with a chain break cap. The pulse is that when the pressure drops, it gets loose in the chain and hits the cap. But is there a chain?
Jan 7, 2019 at 10:59 PM
ARTHUR STITILIS
MEMBER
I changed the sound of the ointments dropped, but remained.
Jan 7, 2019 at 11:02 PM
✓Experienced Mechanic
No, it is a belt. there is no chain at all. the belt will not give you a metal noise at all.
see if someone can drive with you or see if it will make it at idle.
ARTHUR STITILIS
MEMBER
Yes Roy.This sound is standing in the car.
Jan 7, 2019 at 11:12 PM
ARTHUR STITILIS
MEMBER
Maybe the sound of the oil pump?
Jan 7, 2019 at 11:14 PM
there is no video uploaded for me to hear?
Jan 8, 2019 at 1:46 AM
ARTHUR STITILIS
MEMBER
here's the sound:
Video (Click to enlarge)
Jan 8, 2019 at 2:11 AM
Still nothing.
Jan 8, 2019 at 2:38 AM
ARTHUR STITILIS
MEMBER
I'm showing that I sent out. I look forward to the answer. The sound spreads from the bottom.
Jan 8, 2019 at 3:05 AM
Okay, first, remove the belt from the water pump and alternator and see if it is still there.
if it is gone, it could be the water pump.
if it is still there, it sounds like it could the idler pulley for the timing belt. that is under the front cover of the engine.
Image (Click to enlarge)
Jan 8, 2019 at 3:14 AM
ARTHUR STITILIS
MEMBER
Thanks for the diagnosis, I'm going to my sister's on Saturday and I will try to do according to your recommendations. I will contact you and write about the results . Bye
