How does an engine get metal shavings down inside of it?
2010 TOYOTA CAMRY
120,000 MILES • 2WD • AUTOMATIC
CASSANDRAD28
Could it be from them repairing the head on it?
Jul 19, 2021 at 7:14 AM
SQM
  • 6,383 POSTS
If the head was machined and not cleaned properly it can be the cause of metal shavings. Also keep in mind that many times new engine components can create metal shavings.
Keep in mind that microscopic metallic shavings are not a cause for concern unless substantial.
They are usually picked up by the oil filter while traveling through the lubrication system. If you easily visible and excessive metal shavings you need to to an engine flush and oil change to get them out before it cause damage.
Here is a video that you might find helpful:
https://youtu.be/MnqlO3OhNGA
Jul 19, 2021 at 7:30 AM
