Metal in oil and knocking noise
8,000 MILES • 6 CYL • 2WD • AUTOMATIC
KARISSAK6
I had a mechanic look at my car and he said it needed a new head gasket and that was it. He did the repairs. A week later the car started making a knocking noise. The same mechanic is now telling me there is metal in oil and it needs a new rod. Is this something he may have caused or should have noticed when putting in the new head gasket?
Oct 14, 2018 at 5:17 AM
Good evening.
When a head gasket fails, coolant gets into the oil. When it does, it damages the main and rod bearings. The clearance increases and the result is the noise.
I never do a head gasket without replacing the main and rod bearings just for this reason. He should have known this if he is a technician. He did not cause the issue as it is a result of progressive damage from the head gasket failure.
You will now need an engine overhaul to repair this issue.
Oct 14, 2018 at 10:32 AM
