Message center not working
244,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
JUBELEEBOB
Message center does not work at all .just bought this car. Also, no lights on cluster for abs; traction control. .only the check engine light comes on when turn key to on position. The car has remote start, but I did not get the remote. all of the gauges work.
Jun 13, 2016 at 5:18 PM
  • 55,658 POSTS
It sounds like the cluster is bad if all the fuses are good which is common, you will need to get a used one or have it rebuilt, here is a link to show you what you are in for when removing the cluster
https://youtu.be/_HEC44xENxw
Let me know what happens so it can help others
Best, Ken
Jun 15, 2016 at 1:59 PM
