Message says, "traction active" and then it makes a semi loud hum.
Jun 28, 2022 at 8:46 AM
✓Experienced Mechanic
Yep, the traction control/ABS is active while dumping pressure to the brakes. let's run the codes to see what they say so we can fix it. It sounds like the ABS module is bad but to tell for sure follow this guide and video:
