My message center is not lit or displaying any information when I turn on the ignition. The chime works fine and it has the factory radio.
Dec 19, 2016 at 7:41 PM
STEVE W.
✓Experienced Mechanic
Try a reset. Turn key on, hold display button on radio down. Settings will appear on radio. Use seek to select the reset option. Press the preset one button to enable the reset. Press display. Turn key off and then on. If the MC returns you are done. If it does not you will probably need a new instrument panel as it is an integral part.
Dec 20, 2016 at 3:37 AM
TIM CARPENTER
MEMBER
1 POST
Thanks I tried to reset it but it looks like I need a new cluster.
