Message board keeps displaying, low fuel, security, battery and ride control ride
220,000 MILES • V8 • 2WD • AUTOMATIC
JPMACIAS31
After another while driven and then it stop and come back again while driving.
Dec 9, 2019 at 11:38 PM
  • 110,248 POSTS
Since the things are not directly related, it may be a ground issue. Start at the battery. Confirm the terminals are clean and tight. Also, if you can, have the battery load tested to confirm it's good. Low voltage can cause things like this to happen. Most parts stores will load test the battery for free.
Take a look through these links that explain how to test a battery and how to check battery terminals.
Dec 11, 2019 at 10:48 AM
