'98 Villager A/C Electrical
ROOSTERFIRE
Air conditioning operates intermittantly. When operating blows very cold air. I checked the relay and replaced it with the FICD relay (same type just for diagnosis) found that A/C operates normally with FICD relay removed. What is the FICD relay? When both relays are in, the A/C clutch, fan motor and fast idle, cycle on and off abnormally. When A/C relay is only in, the system stays on and doesn't cycle abnormally.
Jan 2, 2007 at 12:19 AM
MERLIN2021
  • 17,250 POSTS
try replacing the pressure switch located on the low side near the firewall.
Mar 5, 2007 at 5:08 AM
ROOSTERFIRE
Thanks Merlin, I forgot to come back and update my question, but that was exactly what it was. I fixed it about two weeks ago, there was high resistance in the low pressure switch. Total cost to fix: $21.00, yeah.
Mar 5, 2007 at 8:00 AM
MERLIN2021
  • 17,250 POSTS
don't forget to vote! and the other thing...the guys who run this arent paying me anything? So all other steps will be appreciated!
Mar 5, 2007 at 9:23 AM
