2001 Mercury Villager shift linkage
183,000 MILES • 6 CYL • FWD • AUTOMATIC
RODDEBOB
I have been having problems with getting my shifter to go into gear. This has been going on for awhile and now it doesn't want to work at all. Do you have any ideas?
Sep 29, 2009 at 11:42 AM
MERLIN2021
  • 17,250 POSTS
First thing to check are the brake light, do they work? If not, there are two switches (sometimes one) on the brake pedal arm, top one is for the shiftlock actuator, bottom one is for the brake lights. Both must work for the shift lock to work.
Sep 30, 2009 at 7:06 AM
RODDEBOB
Okay, thank you. The brake lights work fine but I can not tell about the other switch because sometimes it goes in gear fine and sometimes it doesn't want to go at all! Can the switch be bad just sometimes?
Sep 30, 2009 at 8:20 AM
MERLIN2021
  • 17,250 POSTS
Usually it turns out to be a faulty wire, they tend to break where they bend, unplug the wires, use an ohm meter at the switch with pedal pressed it should have 0 ohms, released it should be infinite...then look at the wires, you may find cracked insulatiion or a bad connection at the end. You might need a sharp probe to pierce the insulation at sevaral pionts and the other lead remains at the connector end, when meter reads OL you have a break!
Oct 3, 2009 at 12:28 AM
