2001 Mercury Villager Hard starting when warm
2001 MERCURY VILLAGER
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
UMBERTORIVERA
Thank you for your answer,
In a cold morning the van starts just fine, but once the car is warmed up it takes about
2 tries to start the van. During the stating process it is a bit erratic, but then settles down.
In idle the car is a bit unstable. I have replaced the spark plugs, spark plug-wires, cap & rotor, and the started was replaced this summer. Any feedback would be appreciated. Thank you.
Nov 16, 2008 at 9:14 AM
JAMES W.
  • 2,394 POSTS
If your injrctors are bleeding down after a warm shutoff, they will actually flood the clyinders a little bit and make a restart hard and a rough running condition for the first minute or so. Hope this helps.
Nov 16, 2008 at 9:44 AM
