2000 Mercury Villager Villager hesitates/stalls/stumbles wh
2000 MERCURY VILLAGER
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SVTBIRD
Mercury Villager drives great then after about 10 minutes, it starts to lose power, stumbles and eventually dies. Read all the OBD II codes and replaced the distributor (cam sensor, coil, ICM), spark plugs/wires, air and fuel filters, front O2 and the knock sensor (what a job that was!). Have had the battery and alternator checked and now there are no OBD II codes other than the rear O2.
Any ideas what to check?
Sep 14, 2009 at 4:59 AM
SVTBIRD
Fuel pressure was in spec. (43psi and 34psi at idle).
Sep 15, 2009 at 5:39 AM
