2000 Mercury Villager Runs roughly and stalls
2000 MERCURY VILLAGER
21,700 MILES • 6 CYL • FWD • AUTOMATIC
PGAVIN
Has run great up until some time ago, when it started driving roughly only in wet weather. Now in dry weather, it starts fine, but drives roughly after warmed up (15-20 min) and then stalls. Will restart, but dies again shortly. Codes said oxygen sensor, knock sensor & cylinder 3 malfunction. Was told knock sensor code could mean it needs a tuneup. Changed spark plugs, wires, distributor cap, rotor, air filter, gas filter, oxygen sensor, PCV valve, cleaned EGR valve, replaced some vacuum hoses. Still runs the same. The knock sensor code still shows. I am in Mexico right now and can�t get a knock sensor. What do you suggest? Thank you.
Dec 27, 2009 at 5:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Does engine miss on cyl. 3? if yes that could set knock sensor code. Also clean MAF heated resistor maybe dirty. And pull vac. hose off MAP does idle change? run better?
Let me know
Thanks for donate
Dec 28, 2009 at 12:50 AM
FIXITMR
  • 9,990 POSTS
i got the SAME ISSUES with mine did you ever find the CURE!?
Dec 29, 2017 at 3:23 AM
