2000 Mercury Villager idle miss
2000 MERCURY VILLAGER
95,000 MILES • 6 CYL • FWD • AUTOMATIC
HAYBOY3491
engine has slight miss at idle under load
Jan 10, 2010 at 6:46 AM
Do you have a check engine light and when was the last tune-up??
Check and test the following below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Jan 10, 2010 at 9:13 AM
