Heater not working
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
LESLIEW
The heater blows cold air has the automatic climate control and I have replaced the climate control head in dash and the thermostat. About 6 months ago had the cooling system flushed and refilled any help on this would be appreciated and how can I get a diagram of the hole system?
Dec 26, 2007 at 5:47 AM
MERLIN2021
  • 17,250 POSTS
Here is how to get the codes from the HVAC system.
The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
To enter the self-test, press the OFF and floor position buttons simultaneously and then press the AUTOMATIC button within two seconds.
The display will show a pulse tracer around the center of the display window. The test may run as long as 30 seconds . Record all DTCs displayed.
This guide can help as well.
https://www.2carpros.com/articles/car-heater-not-working
Cheers
Dec 26, 2007 at 6:01 AM
LESLIEW
Thanks for the guide I found out the engine coolant was low because the water pump we out, I installed a new one now all good. Thanks for the guide really helped.
Dec 29, 2007 at 6:11 AM
