1999 Mercury Villager ENGINE SEEMS TO FEEL LIKE TO SHUT OFF
1999 MERCURY VILLAGER
14,200 MILES • 6 CYL • 2WD • AUTOMATIC
BIGAL81875
HI, I HAVE A 1999 MERCURY VILLAGER ESTATE IT HAS 142,000 MILE . I HAVE A PROBLEM I CANT FIGURE OUT. WHEN IM AT A LIGHT THE CAR WILL FEEL LIKE IT ABOUT TO TURN OFF IT WILL IDLE ROUGH WHEN DRIVING IT RUNS FINE. I CHANGE THE WIRES AND SPARK PLUGS AND FUEL FILTER. IS THERE ANYTHING ELSE THAT I CAN CHECK.
Apr 4, 2008 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
check and clean throttle body
check for vacuum leaks
check mass air flow sensor
do u have check engine
will help if you scan for codes
Apr 13, 2008 at 9:35 AM
