1999 Mercury Villager Engine died
1999 MERCURY VILLAGER
180,000 MILES • 6 CYL • FWD • AUTOMATIC
ALANB57
The engine just died while driving. turns over good. removed fuel line, has fuel, what could be wrong?
Sep 3, 2010 at 5:47 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 3, 2010 at 10:40 PM
