1999 Mercury Villager Coolent Leak
146,000 MILES • 6 CYL • FWD • AUTOMATIC
BAJAGEORGE
I have a coolent leak that appears to be coming from the bottom side of the throttle body. I have replaced hoses on both sides and still have a leak somewhere. Can you suggest other possible places it might be leaking? Can you send me a diagram? I would appreciate a response a.s.a.p. Thank you.
Nov 21, 2008 at 4:02 PM
STEVENFOX54
I also have a 1999 Mercury Villager with 148,000 miles and it is also leaking coolant from the throttle body. It apears to be leaking from the area in front where the piston moves the high idle speed cam. The plate has 2 screws holding it in place but I am not sure it I can remove and regasket it. Hate to buy a new throttle body but can not find where anyone has repaired this throttle body. If you have discovered any thing on repair please let me know.
Thanks Steve
Dec 27, 2008 at 1:51 AM
