1999 Mercury Villager BRAKES
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAISO
HI I WAS WONDERING WHY MY BRAKE PEDAL ON A 99 VILLAGER GO ES HALF WAY TO THE FLOOR BEFORE STARTING TO STOP. I CHANGED FRONT AND BACK PADS AND SHOES AND SEEMS THE SAME AS WHEN THE OLD PADS WERE ON.THANK YOU
Apr 2, 2010 at 8:19 AM
BMRFIXIT
  • 19,053 POSTS
Misadjusted rear shoes could be the problem
Check and adjust rear shoes
Check if brake hydraulic system leaking
Check brake lines and wheel cylinders for leaks
air in system
Apr 14, 2010 at 10:13 PM
