1999 Mercury Villager alternator
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALFONSO
I need instructions on how to remove the alternator
Oct 28, 2008 at 1:40 PM
BMRFIXIT
  • 19,053 POSTS
CAUTION: When battery is disconnected, vehicle computer and memory systems may lose memory data. Driveability problems may exist until computer systems have completed a relearn cycle.
Removal & Installation
Disconnect negative battery cable.
Raise and support vehicle.
Remove engine splash shield.
Remove generator adjuster bolt.
Remove 2 generator mounting bolts and support generator.
Rotate generator to access electrical connections.
Disconnect electrical connections and remove generator from vehicle.
To install, reverse removal procedure.
Tighten fasteners to specification
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 1:44 PM
