1999 Mercury Villager Air Filter
1999 MERCURY VILLAGER
CHUCKLAWSON
Engine Performance problem
1999 Mercury Villager 4 cyl Two Wheel Drive Automatic
I must have an IQ of oil but how do you change the air filter...I can't get the housing off.
Thanks!
Dec 15, 2009 at 12:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Lift the hood of the Mercury. Locate the air filter housing unit along center of the side of the engine compartment, on the driver's side of the car. Open the lid on the air filter housing unit by unscrewing the screws that hold it in place. Lift the lid off of the unit. Remove the old filter from the housing unit. Clean any remaining debris out of the air filter unit. Don't use water to clean out the unit, it could damage the engine. Place the new air filter in the housing unit. Use a K&N air filter, part number 33-2091-1, for a Villager manufactured between the years of 1993-2002. Use only the part number recommended for the Villager, a different model or part number can cause severe engine damage. Close the lid on the housing unit. Secure the lid in place by tightening all of the screws.
Jan 30, 2010 at 12:30 PM
