1998 Mercury Villager Knock Sensor
DANDELTORO
Engine Mechanical problem
1998 Mercury Villager 6 cyl Front Wheel Drive Automatic
I replaced the knock sensor on this Villager because I was getting a "knock sensor" code on my OBD2 scanner. The car was running but would miss sometimes. Now that I have changed it, the car will not turn on.
Sep 12, 2008 at 12:25 PM
KHOOPER
  • 22 POSTS
check your battery voltage if low 11.0 volt maybe that is problem try new battery, or better see a mechanics to be sure.
Sep 12, 2008 at 12:53 PM
