1998 Mercury Villager
83,616 MILES • 6 CYL • 4WD • AUTOMATIC
ECH224
Originally my transmission was changing late, it wouldn't change gears until 30 miles per hr. Now,It will not switch gears at all. when i put it on drive, it stays on low gear while i'm driving. It will not go automatically to the next gear. Reverse works, Drive works, but it will not shift automatically or manually while i'm driving. If i shift it Manually to the first gear and then to the second gear and then into drive, it will stay on the first gear. My transmission fluid is good nd filter is good. What part in my transmission would be causing this problem?
Sep 18, 2010 at 5:33 AM
KHLOW2008
  • 41,812 POSTS
Hi ech224,
Thank you for the donation.
Does the OD OFF indicator blinks for about 8 seconds when ignition is turned ON? If yes, get a free scan done at Autozone and let me know the EXACT trouble codes.
It could be a failed transmission, control unit or valve body.
Sep 18, 2010 at 6:39 AM
