1997 Mercury Villager strut assembly
LUCKY7
1997 Mercury Villager 6 cyl Two Wheel Drive Automatic 110k miles
I am going to order(online) 2 strut assemblies and I want to get everything I will need in one order. What else should I order for this job? The bellows look fine, the mounts look fine, but how about spacers, bearings, bushings-or should I just wait and buy other parts locally as needed?
Mar 8, 2009 at 5:16 AM
ZACKMAN
  • 4,202 POSTS
You can order the strut kit that everything comes pre-assembled. All you have to do is remove the old assembly, and install the new one. No messing with removing spring from struts and all.
The other is to purchase the rest of what you need locally, so at least you can return it if you don't need it.
Mar 10, 2009 at 6:26 PM
