1997 Mercury Villager Rear brake leak
262,000 MILES • 6 CYL • FWD • AUTOMATIC
NJANGLER
While driving home last night, I suddenly lost my brakes. I managed to drive home safely, and found that there was a leaking of brake fluid on the driver side rear brake. I filled up the reservoir with fresh brake fluid, and pumped the brakes. I changed the pads and drums about a year and a half ago. I'm not sure if the brake line got nicked somehow. Is this an easy fix for a home mechanic?
Feb 5, 2008 at 12:55 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6da729180a="NJAngler"]Brakes problem
1997 Mercury Villager 6 cyl Front Wheel Drive Automatic 262000 miles
While driving home last night, I suddenly lost my brakes. I managed to drive home safely, and found that there was a leaking of brake fluid on the driver side rear brake. I filled up the reservoir with fresh brake fluid, and pumped the brakes. I changed the pads and drums about a year and a half ago. I'm not sure if the brake line got nicked somehow. Is this an easy fix for a home mechanic?[/quote:6da729180a]
have a helper pump the brake while you look for the leak if its coming from the inside of the drum u need a wheel cylinder
check lines and hoses
its possible to be done
Feb 5, 2008 at 1:12 PM
