1997 Mercury Villager intake manifold removal
225,000 MILES • 6 CYL • FWD • AUTOMATIC
AS IT IS
Looking for advice on how to remove / which hoses to remove, along with other connections at the rear of the intake manifold.
The upper intake manifold needs to come out to gain access to the small coolant pipes mounted under the intake manifold -- the rubber hoses are deteriorated on each end of these coolant pipes (these pipes direct coolant to the throttle body). These coolant lines are visible through the fingers of the intake manifold, but not accessable enough to replace with the manifold installed.
Jun 13, 2008 at 5:38 AM
BLACKOP555
  • 10,386 POSTS
remove and mark every hose and cable attached to the manifold and throttle body, take off the throttle body and manifold as one part just disconnect all.
Jun 13, 2008 at 9:42 AM
