I purchased a 1996 Mercury Villager with a transmission problem.
It shifts from 1st gear to 3rd gear.
It never goes into 2nd gear or overdrive.
I will not shift manually into 2nd gear if you "pull it down."
I need 2nd gear for those steep hills here in TN.
I replaced the TCM and the shifting solenoids on the valve body but still have the same trouble.
I noticed that the previous owner replaced the TPS at some point.
Should I just try a new valve body?
How do i check the transmission codes?
Nov 8, 2010 at 6:26 AM
