car smells of gas in the car while driving, and under the hood when looking.
Mar 3, 2009 at 10:55 AM
BLACKOP555
✓Experienced Mechanic
check for leaks around the fuel pressure regulator and gas lines first. then check around the injectors and fuel rail. also check the carbon/charcoal canister.
if thats all good check the pressure, if the pressure is too low it can smell very gassy.
