1995 Mercury Villager wont start
KILJDC
  • 1995 MERCURY VILLAGER
Engine Performance problem
1995 Mercury Villager 6 cyl Two Wheel Drive Automatic
while I was driving it just died on me now it sounds like it wants 2 start but wont what could be the problem
Sunday, May 3rd, 2009 AT 3:41 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, May 3rd, 2009 AT 5:48 AM
