The heater blows great heat while excellerating, but when you let off the gas, the air from the heater turns cool again
Nov 27, 2009 at 3:19 AM
✓Experienced Mechanic
Test or replace the thermostat and check coolant level for a start
Nov 27, 2009 at 8:53 PM
AL3177
MEMBER
I already replaced the thermostat and the coolant level is ok.
Someone said that there's a little door that has to open to let the air through and maybe that's the problem. I don't know.
Thanks,
al
Nov 27, 2009 at 11:45 PM
ANDREWBASHAM
MEMBER
I have the same type of problem with my 98 Villager. If I hold the engine at 3000rpm the rear hearter works as well. Could our problem be air in the system? Would "bleeding cooling system" help?
Nov 28, 2009 at 12:42 PM
ANDREWBASHAM
MEMBER
I dusted off my Haynes Repair manual for 93-01 Villager.
Chapter 1-23 talks about refilling the system after
servicing the cooling system. It goes step-by-step
on bleeding the system.
It takes a little time but it worked!
Setting still in the driveway and I got hot air front
and back!
Grace,
Andrew
