1995 Mercury Villager oil pump
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRUSH59
oil light flashes on and off!!!had oil changed and ran an oil flush through it then changed the oil the light still flashes on and off. also makes a slight tapping noise when it warms up. oil pump????
Mar 1, 2008 at 4:42 AM
  • 75,988 POSTS
Could be the oil pump getting sloppy-you need to check the oil pressure with a mechanical gauge-
Mar 1, 2008 at 5:42 AM
