I am not a mechanic but it should be easy. Follow the host from TOP of your radiotor to the engine. It's usually on the engine side of the hose. MAKE SURE YORU ENGINE IS COOL AND NO PRESSURE INSIDE THE HOSE. If the hose is soft there should be no pressure. I usually unplug the hose with a small container or whatever under to catch any coolant. Remove the host on the engine side, make sure you look at the orientation of the thermo and replace it back with correct side up. You can google how to replace thermostat also :-) You can should be able to do it within 30 min :-)
SPONSORED LINKS
Tuesday, February 24th, 2009 AT 2:24 PM
