1995 Mercury Villager
KEVIN_LAVERPOOL
  • 1995 MERCURY VILLAGER
Transmission problem
1995 Mercury Villager Four Wheel Drive Automatic 10000 miles
my 1995 mercury villager will not start and I have charged the battery
Monday, August 23rd, 2010 AT 5:34 PM
Pick your symptom:
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Monday, August 23rd, 2010 AT 7:31 PM
