Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Villager
Engine
Symptoms
Not Running
1994 Mercury Villager Won't Start
1994 MERCURY VILLAGER
128,000 MILES • 6 CYL • FWD • AUTOMATIC
RPRZYBYLO
MEMBER
The vehicle cranks over but will not start has fuel pressure. Starts when starting fluid is sprayed but stalls after.
Nov 2, 2009 at 2:44 AM
Experienced Mechanic
Check the fuel pressure to rule the fuel pump and also check for injection pulses from the injector/s
Nov 2, 2009 at 3:17 AM
RPRZYBYLO
MEMBER
the injector has no pulse but how would i fix that?
Nov 2, 2009 at 3:25 AM
Check for power on the injector harness and if its there and still no pulse test the injector and also the computer's ground driver/s
Nov 2, 2009 at 3:28 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
