1994 Mercury Villager when you press the brakes
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDGAR5
When i press my brakes in a stop or red light my car starts to accelerated and the pedal goes to the ground. Took it to a garage they told me it was the master cylinder. Change it and it still doing the same thing. They charge me $ 250.00. what else could it be the problem. I think it may be the Booster. how to check it.
Nov 4, 2010 at 3:04 PM
WRENCHTECH
  • 20,760 POSTS
If the pedal starts good and then drops slowly, it's called bypassing. If you are not losing any fluid, the most common cause is a bad master cylinder but in some rare cases it can also happen in the ABS unit, especially if it is a rear wheel only system.
Nov 5, 2010 at 12:36 AM
