1994 Mercury Villager Accessories Malfunctioning
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLIFF CARLSON
Over the past year, some accessories have stopped working properly. First, AC cut out out, then the radio stopped working, and the interior fan (no heat!)and now the rear window wiper won't shut off. I'm suspecting that the computer is faulty. Can I test it with a code reader? Where is the computer located? Thanks!
Nov 7, 2008 at 10:12 PM
BMRFIXIT
  • 19,053 POSTS
The only relation I see between is the BCM module and I am not sure if your have one or not
code reader will not communicant with BCM u need a scanner
check wiring and components
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 7, 2008 at 10:44 PM
