i have a 1993 mercury villager van recently it began to run hot after longer rides on the freeway but when i turned on the heater the temp would drop...i tried to see if temp would go up further as it was one click past normal running temp...then it started to get hotter more often...now it is getting real hot..i have checked hoses and there are no leaks..the water pump seems to be fine as it would over heat in the driveway...the lower hose when i grabbed felt empty after i tried turning it on after letting it cool for awhile...the fan also seems to kick on so does this seem to be a thermostat problem or is there something else i should look at???
Aug 26, 2008 at 7:35 AM
