Engine Performance problem
1993 Mercury Villager Front Wheel Drive Automatic
I changed my MAF sensor cause the car had a real bad hick up problem til it felt like it was going to stall then the car died the key turned but nothing else I took a guess and changed the MAF sensor and now the car runs but still has a lil hick up problem should i also change the o2 sensor also changed plugs coilpack and cap and rotor
It only seems to act up after you drive for a while when i come to a stop in drive the engine idle drops then it levels out or when i put it in reverse in park it rarly does it
May 4, 2010 at 11:01 PM
