1993 Mercury Villager grinding noises
1993 MERCURY VILLAGER
200,000 MILES • 6 CYL • FWD • AUTOMATIC
SEDECKA
working on this van installed new cv joints and axles stilling making a grinding sound sounds like something is rubbing metal to metal in the cv joint and axle area brakes looked good some one said they had a problem with crankshaft pulleys can't hear sound at idle only while driving
Feb 26, 2010 at 2:19 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
can you identify which side it is coming from?, as it is only when the shaft is turning, there should only be one or two possibilities, rotor touching backing plate, pads, drive shaft in housing touching wheel bearing, you may be able to hear or feel something by jacking up the car and turning one wheel at a time by hand, try this.
mark (mhpautos)
Feb 26, 2010 at 11:07 AM
