1993 Mercury Villager air sensors
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUSSTEE
I will be replacing the mass air flow and oxygen sensors in the next few days and am not sure of there location or procedure. Any help would be greatly appreciated.
Apr 15, 2008 at 2:46 PM
2CARPRO JACK
  • 11,533 POSTS
Can I ask why you are replace all of those parts? If you continually get "lean bk1, lean bk2" codes, then it is either a vacuum leak in the common plenum of the intake or more likely the Mass Airflow Sensor.
Apr 16, 2008 at 4:05 AM
