99 Merc Tracer P1506, P0455
L2ROCKU2
Hey All. 1999 Mercury Tracer, 2.0 SOHC, Automatic, 124K. Purchased 3 mths ago after a lube shop replaced the head gasket. Check engine lights been on since the 2nd day. P1506 (IAC overspeed) P0455 (Gross leak) only codes left to fix. Idles btwn 1400-2000 warm or cold. When a/c compressor engaged, idle falls to 800-1000 but vehicle shakes very bad and (with brake applied) squealing from belt. Not enough vacuum at EGR valve to move the needle on hand gauge(at any time). Work completed= New plugs & wires-Almost all rubber vacuum lines replaced-ALL vacuum lines(rubber/plastic) checked and no leaks-Cleaned MAF sensor-Replaced Catalytic converter, PCV valve & both O2's-Removed & cleaned IAC-Throttle body-EGR valve & new gaskets-NO intake manifold leak found. IAC valve activates when unbolted & ignition turned to on but no change in rpm's when unplugged (installed). I hope you can help !!!! THANKS !!!!!
Dec 19, 2006 at 7:17 PM
CARUNDELL
  • 602 POSTS
[quote:a1ea2b990d="L2rocku2"]Hey All. 1999 Mercury Tracer, 2.0 SOHC, Automatic, 124K. Purchased 3 mths ago after a lube shop replaced the head gasket. Check engine lights been on since the 2nd day. P1506 (IAC overspeed) P0455 (Gross leak) only codes left to fix. Idles btwn 1400-2000 warm or cold. When a/c compressor engaged, idle falls to 800-1000 but vehicle shakes very bad and (with brake applied) squealing from belt. Not enough vacuum at EGR valve to move the needle on hand gauge(at any time). Work completed= New plugs & wires-Almost all rubber vacuum lines replaced-ALL vacuum lines(rubber/plastic) checked and no leaks-Cleaned MAF sensor-Replaced Catalytic converter, PCV valve & both O2's-Removed & cleaned IAC-Throttle body-EGR valve & new gaskets-NO intake manifold leak found. IAC valve activates when unbolted & ignition turned to on but no change in rpm's when unplugged (installed). I hope you can help !!!! THANKS !!!!![/quote:a1ea2b990d]
Hey L2,
Believe it or not that p0455 could be the culprit of your high idle p1506. the evap system is all under a vacuum. I'd try to rule out the vacuum issues at the evap canister first. Or ...... disconnect all vacuum to it underhood ...evap solenoids and see if your idle self corrects. I would also recommend to verify vacuum hose routing. Let us know!
Chris
Dec 19, 2006 at 8:08 PM
2CARPRO JACK
  • 11,533 POSTS
Definitly sounds like a vacuum leak.Inspect and test the canister and the control solenoid.For it to set that code it should be a fairly obvious leak
Dec 19, 2006 at 11:27 PM
L2ROCKU2
I replaced the EGR vacuum solenoid- NO change !! When I can, I'll double check the canister. Thank You, 2carpro & carundell, MUCH appreciated !!!!
Jan 11, 2007 at 1:22 AM
