1999 Mercury Tracer Will not start
44,000 MILES • 4 CYL • FWD • AUTOMATIC
CURIK
Battery new. Will start sometimes but other times, it requires a jump. This usually happens after electrical guages, radio, speedometer will stop working and then it will not turn over without a jump. Battery test good but replaced anyway. Ran good for three days and started same problems. First radio wipers dont work, fuse bad so replaced fuse but now wiopers will not stiop running and it will not turn over without a jump. Where do I start looking for the electrical problem?
Apr 10, 2008 at 1:26 AM
  • 75,988 POSTS
I would start with the ignition switch and double check all connections at battery and starter relay
Apr 10, 2008 at 5:03 AM
