1999 Mercury Tracer
1999 MERCURY TRACER
139,500 MILES • 4 CYL • FWD • MANUAL
JASONCRAIGER2
my ? is what would cause multiple things to go out at the same time. Here is a small list of the problems with my car. The speedometer, horn, high beams, cruise control.
Aug 16, 2010 at 12:38 AM
  • 31,937 POSTS
Hi there,
have you checked the fuses,
I would be checking the main loom for a loose cannon plug, ore loose plug pins. i feel that it will be a common problem if they all failed at the same time.
mark (mhpautos)
Aug 16, 2010 at 12:46 AM
JASONCRAIGER2
I have checked all of the fuses with a test light. and all of the fuses checked out ok, meaning the the test light lit up when i put the poker on both sides of the fuse. question where is the cannon plug located at. and how easy is it to check for this problem?
Aug 17, 2010 at 12:15 AM
  • 31,937 POSTS
There are a number of plugs, most are hidden under the dash, follow the loom down the steering column and start there.
Mark (mhpautos)
Aug 17, 2010 at 12:21 AM
