1997 Mercury Tracer No spark #2 & #3
MYOWN
1997 Mercury Tracer 4 cyl Two Wheel Drive Manual
I have a 1997 Tracer with a with 180 thousand miles it stalled was able to get it started but ran rough I changed timing belt ,spark plugs, plug wires , still would start hard and run rough I checked for spark #2 & # 3 no spark I changed coil pack still no good A friend sugjested computer so I changed it still no spark. where do I go from here.
May 11, 2009 at 3:44 AM
  • 75,988 POSTS
Could be faulty wiring, ignition control module and crankshaft positioning sensor-
May 11, 2009 at 5:48 AM
MYOWN
I have the repair manual and have replaced the Crank shaft sensor but nethier has helped it looks as if this is a reocureing problem with this car there seems to be a lot of people on your list that have had the same problem
May 11, 2009 at 6:51 AM
  • 75,988 POSTS
You need to double check the ICM and CPS
https://images.2carpros.com/forum/automotive_pictures/12900_cps_29.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cps1_9.jpg
May 11, 2009 at 11:11 AM
