1997 Mercury Tracer insufficnt egr flow code p0401
173,000 MILES • 4 CYL • FWD • AUTOMATIC
DSIEWERT
I have a code that states insufficent egr flow.there is no vacuum leak and the engine performs flawlessly. What is the chance that the egr valve is the defective part on this car. I removed the valve and cleaned it w carb cleaner.How do I reset the check engine light and if not the egr valve what else could it be?????
Dan
Nov 25, 2008 at 12:18 PM
BMRFIXIT
  • 19,053 POSTS
Out the egr tube comes two small hoses that they go to a sensor
its called DPFE sensor
98% its no good
replace it good luck
Nov 25, 2008 at 12:26 PM
