1996 Mercury Tracer is it the alternator?
1996 MERCURY TRACER
SWEETANGER
1996 Mercury Tracer 4 cyl Automatic 128800 miles
i was driving my car today and all of a sudden the rpm gauge, radio, and heat just quit on me. then started working. when i left to go home, the car lights dimmed, inside and out, the battery light, and check engine light, and airbag light came on, then all of the lights went out and the car died. is it the alternator or the crank shaft, or the battery?
Apr 5, 2009 at 5:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty battery or alternator. You will need to have charging system tested before replacing anything. If battery and alternator are OK, inspect battery cables to ensure all connections and tight and clean.
Thanks for using 2CarPros.com!
Apr 5, 2009 at 5:55 PM
