1995 Mercury Tracer Radiator fan not coming on
143,000 MILES • 4 CYL • 2WD • MANUAL
PAT SCIB
Radiator fan not coming on. Already changed fan motor, broken thermostat, relay in fuse box under hood, all associated fuses. Still no fan action. Is it a fuse link and where do I find them? Thanks in advance. ~Pat
Aug 18, 2008 at 12:12 PM
PAT SCIB
Actually I found the problem with the fan not coming on. There are two more seriously hidden relays. Unbolt the air filter housing (12mm socket, 3 bolts). Move that out of the way and near the fender there is a rectangular shaped object with one 10mm bolt holding it on. Its there hiding. Unbolt it, its a rubber boot on it covering the last two relays. Mine were melted. Advanced was gonna special order one that they could have gotten for $70 but not the other. Forget that. I went to the ford dealership and ordered the right ones, both for less than $70. The problem is one of the wiring harnesses melted, but I'll get around that. Also you can used non OEM relays if you feel up to it. This link will tell you how to do it: https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Aug 19, 2008 at 1:28 PM
