1995 Mercury Tracer idle problems
ARMYCOWBOY
Engine Performance problem
1995 Mercury Tracer 4 cyl Front Wheel Drive Automatic
the car idles real rough and low if sitting at idle for just a little bit will kill the car but starts right back up. im thinkin there is a vaccuum leak or timing problem, please let me know what you think
Jan 10, 2009 at 7:33 AM
  • 75,988 POSTS
Lets try cleaning out the idle air contrrol valve and see what happens
Jan 10, 2009 at 7:51 AM
AIDAN_80
  • 41 POSTS
I had the same problem!
My timing belt jump a tooth or two.. by the time I found it was the belt it had jumped enough teeth till the car wouldn't start anymore. I also had a check engine come on before the belt went for the IAC. Cleaned the IAC and it's still shaking.. need to get another IAC now as well!
Jan 20, 2009 at 1:25 PM
