1995 Mercury Tracer
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
COLLIN17CARS
My Car is idling at 1000 rpm or less when a stop --- when ever i come to a stop it would stall --- what would the cause of this be???
May 25, 2010 at 11:15 AM
  • 31,937 POSTS
Hi there,
The idle speed is controlled by the ECU, there is no adjustment, if there is an idle problem check the throttle plate is clean, check for vacuum leaks and have the idle control motor check, start here.
mark (mhpautos)
May 25, 2010 at 11:56 AM
