1994 Mercury Tracer wiring is fubar
135,000 MILES • 4 CYL • FWD • AUTOMATIC
ALSBIGASS
O.K. i bought this car for 150 dollars runs good once i hot wire it. it does flash a code 32. at the ecm there are 2 orange with blue stripes that come out. both were cut at the ecm. one was replaced with standard house speaker wire and went to a connector in front of cooling fan. the orange and blue wire was cut to close to connector so they wired to the blue and red wire that comes from other side of connector. it is a ten pin i think. what are the ornge and blue stripe wires for and i found the first one but the second one goes to the o2 sensor but no idea where to find the end to reconnect. and could this cause the ignition to blow out. once i get this wiring stuff figured out i have more question but im hoping this fixes most problems
Nov 15, 2009 at 1:26 AM
MERLIN2021
  • 17,250 POSTS
Need to know if it's 1.8 or 1.9?
Nov 15, 2009 at 1:57 AM
